• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Other Analog & Touch » Temperature Sensors » Temperature Sensors Forum » TMP102 Electrical Characteristics and Clocking
Share
Temperature Sensors
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 1 day ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 2 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 8 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question has suggested answer(s)
David Merrill
Posted by David Merrill
on Mar 20 2012 11:23 AM
Intellectual2070 points
ELECTRICAL CHARACERSISTICS:
Question 1
It only indicated Vol SDA and Vol ALERT
What are value when SDA and ALERT Pin goes to high (logic ‘1’) and what is its range?
AT page 9 BUS OVERVIEW:" the device that initiates the transfer is called a master, and the device controlled by the master are slaves. The bus must be controlled by a master device that generates the serial clock (SCL), controls the bus access, and generates the START and STOP conditions. "
 Question 2:
When TMP102 sends data bytes back to the bus, is the TMP102 considered as master or slave?  And does it generate clock, start, stop bit?
Generate clock?  Or the TMP102 never generate clock signal?
Look the Figure 14, Two-Write Timing Diagram for Read Word Format
Master controls the clock for first two write cycle. When TMP102 send back to master two temperature bytes,does TMP102 control the clock (TMP102 generating the clock signal at SCL line) or still the master has to generate the clock signal.
  Question 3:
Does the clock input to the chip need to be 50% duty cycle?
Looked at Figure 14 in datasheet.
Thanks.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Chris Featherstone
    Posted by Chris Featherstone
    on Mar 20 2012 12:47 PM
    Suggested Answer
    Expert5125 points
    David,
    SDA and ALERT will be at the rail voltage when they are high (logic 1). The reason is because SDA and ALERT are open collectors and the pull up resistors will pull the output to the rail voltage in the case of logic 1 (high).
    The TMP102 will always be the slave device while the microprocessor will always be the master.
    The I2C protocol states that the Master is the device which initiates a transfer, generates clock signals and terminates a transfer.
    On page 14 you will see the timing diagram. The microprocessor initiates the communication with the TMP102, generates the clock signal (SCL) and tells the TMP102 when to send data. The microprocessor will then end the communication.
    I would recommend using a 50% duty cycle. This is the most common and will be easiest to implement.
    Chris Featherstone
    Linear Characterization Engineer
    High Performance Linear Products
    ALERT TMP102 SDA Slave Master
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
