• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Other Analog & Touch » Temperature Sensors » Temperature Sensors Forum » LM96080 fully compatible with LM80?
Share
Temperature Sensors
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 1 day ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 2 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 8 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
Gabriel Perez
Posted by Gabriel Perez
on Mar 29 2012 13:50 PM
Prodigy40 points
My question is basically centered around the fact that ADC values stored for the LM96080 are 10bit long vs 8bits in the LM80.
I'm trying to figure out how the part maintains SW  compatibility given the that the width of the returned data (expected) is 10 and not 8.
The only thing I can think of is truncation of the lower 2 bits, but I have not being able to receive an official confirmation from TI.
Can someone help?
Local temperature I2C Temp Sensor Monitor Temperature Temperature Sensor Device I2C bus Fan Control interrupt
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Emmy Denton
    Posted by Emmy Denton
    on Apr 02 2012 13:30 PM
    Verified Answer
    Verified by Gabriel Perez
    Intellectual1565 points
    Hi Gabriel,
    See attached file for a detailed comparison of the two devices. If you need anything else please let me know!
    Take care,
    Emmy Denton
    Precission Systems Applications
    Silicon Valley Analog
    Texas Instruments
    8321.LM96080toLM80Comparison20120402.zip
    Emmy
    Integrated Signal Chain Applications
    Texas Instruments
    Report Abuse
    • Reply
  • Gabriel Perez
    on Apr 02 2012 14:35 PM
    Prodigy40 points
    Tha attachment helped a lot with the question I posted above. However, there is one more detail concerning
    the "pin compatibility" for both parts:
    Supply Voltage: Does the LM96080 take supply voltages as low as 2.8V like the LM80? I can see from the data sheet it is not the case, but just wanted to confirm.
     Hysterisis Voltage: What is the hysterisis voltage for LM80? these values are presented in the LM96080, but there is no information on its equivalent for the LM80. It would be nice to have this data to evaluate full compatibility.
    Monitor Temperature Fan Control
    Report Abuse
    • Reply
  • Emmy Denton
    on Apr 12 2012 14:20 PM
    Verified Answer
    The parts are pin compatible. As a matter of fact if you have source code for the LM80, you should be able to put the LM96080 down on the board and it should work. You should only need to change your code if you want to take advantage of the extended resolution of the LM96080 or some other function as listed in the document I sent you.
    As for your new questions:
    Supply Voltage: as the comparison document states the LM96080 is only guaranteed for operation down to 3.0V and up to 5.5V. There is a whole section that describes the power supply differences. Please read it.
    Hysteresis Voltage: both devices have comparable hysteresis - we just did not specify it on the LM80. No worries here either.
    Take care,
    Emmy
    Precision Systems Applications
    Emmy
    Texas Instruments
    Report Abuse
    • Reply
  • Gabriel Perez
    on Apr 12 2012 16:03 PM
    Prodigy40 points
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
