I am in the prototyping stage useing the TMP006. I have two questions:
1. Do you sell a development board with the TMP006 mounted on it using your recommended layout?
2. Using a magnifier, I cannot find a marker on the chip to enable me to determine its orientation. I did not find any references in the data sheets to a marker. Assuming that I will be able to come up with a way to mount the chip, is there a way of determining its orientation?
Thank you,
Travis Metcalf
Metcalf Engineering
metcalfengineering@cox.net
Hello Travis,
Ian WilliamsLinear Applications EngineerPrecision Analog and Sensing Products
Thank you for your quick response. You did answere my questions quite adequately. I will evaluate the other simpler TI temperature sensors for my project before going with the more difficult TMP006 thermopile sensor.
