• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Other Analog & Touch » Temperature Sensors » Temperature Sensors Forum » LM335 question
Share
Temperature Sensors
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    This amplifier doesn't exist...now what!?
    Posted 14 hours ago
    by Xavier Ramus
    Sometimes it’s impossible to find an amplifier with the...
    Cable equalization 101 – Automating your design
    Posted 3 days ago
    by Hooman Hashemi
    Judging by the number of views on a post related to numerical...
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 7 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
LM335 question
LM335 question
This question is not answered
derick petrey
Posted by derick petrey
on Apr 02 2012 12:15 PM
Prodigy20 points
Hello, recently ive taken on a project involving temperature, an ic i found laying around was LM335 and according to datasheet it seems easy enough to interface to using a microcontroller. Using the equation from the datasheet  Vout_T = Vout_To * (T/To) and then converting to degrees F by use of 9/5*C + 32, the conversion works just fine but im using the TO-46 package to measure the ambient temp in my living room and it seems like the sensor is not sensitive enough in free standing air? it seems it responds great when i touch the sensor to something cold or hot.
So i guess my real question is how can i make the LM335 measure temperature accurately in say my living room a big open space with rather still air?
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Emmy Denton
    Posted by Emmy Denton
    on Apr 12 2012 14:24 PM
    Intellectual1585 points
    Hi Derick,
    The big open space with rather still air will probably change temperature very slowly. So perhaps it is measuring the right temperature? You need to make sure it's not touching a wall or something similar as that will influence the temperature sensor greatly.
    So how do you know the temperature is not accurate?
    Take care,
    Emmy
    Precision Systems Applications
    Texas Instruments
    Emmy
    Temperature Applications
    Integrated Signal Chain
    Texas Instruments
    Report Abuse
    • Reply
  • derick petrey
    on Apr 12 2012 14:42 PM
    Prodigy20 points
    I have a digital thermometer and a mercury thermometer that both agree, and the fact that its really cold in here wen i open say a window and the voltage changes but only by a small amount. So the temp sensor seems to think its 76 degrees when its actually like in the 60's.
    When i calibrate the sensor at 77degrees F or 25 C do i leave the pot hooked up for good, or do i calibrate it and then un-hook the pot? I leave it hooked up after i calibrate for 2.982V @ 25 C
    It seems to me the case is not changing temp in the free-air, but it does react nicely if its set next to a "cold" source or a "hot" source
    Thank you look forward to a reply
    Report Abuse
    • Reply
  • Emmy Denton
    on Apr 19 2012 16:12 PM
    You will need to leave the pot connected. Also the LM334 may have a slower thermal response time than the thermometer you are using and probably "filtering" the small temperature changes. You could try to lower it's thermal mass. Mount it on the end of some very long fine wires and see what you get. I assume that it's now mounted on a PCB. Leave the POT on the PCB, just remove only the LM334.
    Take care,
    Emmy
    Texas Instruments SVA
    Emmy
    Texas Instruments
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
