• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Other Analog & Touch » Temperature Sensors » Temperature Sensors Forum » Temperature sensor recommendation
Share
Temperature Sensors
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 2 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 3 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 9 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is not answered
JustGreg
Posted by JustGreg
on Apr 04 2012 03:38 AM
Expert2550 points
Hi!
I'd like to measure the temperature of two heated metal blocks with the size of a box of matches. One block should be around 50 degrees Celsius, the other one is 95. The controller type is not decided yet but most likely it will be an on/off or PID, running by a MSP430. I'm looking for a voltage or digital output temperature sensor for this purpose, +/- 1 Celsius accuracy would be sufficient. The measuring point would be inside the blocks, and the main electronics would be not too far from sensors (10-20 cm). I'd also like to ask how higher temperature (95 C) will affect the digital communication lines (p.e. I2C) between a digital output sensor and the main electronics?
Thank you.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Chris Featherstone
    Posted by Chris Featherstone
    on Apr 04 2012 20:31 PM
    Expert5125 points
    Greg,
    I would recommend looking into the TMP112. It's accuracy (temperature error) at most will be 0.5oC from 0oC to +65oC. In the range of -40oC to  +125oC it's accuracy (temperature error) at most will be+/-1oC.
    I am currently looking into your second question and will get back to you soon.
    Chris Featherstone
    Linear Characterization Engineer
    High Performance Linear Products
    Report Abuse
    • Reply
  • Emmy Denton
    Posted by Emmy Denton
    on Apr 19 2012 17:14 PM
    Intellectual1565 points
    Hi Greg,
    How will you be mounting the sensors to the blocks? Should they be fairly small?
    Thanks!
    Emmy
    Precision Systems Applications
    Texas Instruments SVA
    Emmy
    Integrated Signal Chain Applications
    Texas Instruments
    Report Abuse
    • Reply
  • JustGreg
    Posted by JustGreg
    on Apr 23 2012 06:14 AM
    Expert2550 points
    Hi Emmy,
    thank you for your reply. The mounting method depends on the sensor's package so we need to find the appropriate sensor first. The blocks would be around 60 x 50 mm and their thickness is around 20...25 mm. One possible mounting method is where the sensor would be placed inside a drilled hole, which would be filled up with thermal grease.
    Thank you.
    Greg
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
