• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Other Analog & Touch » Temperature Sensors » Temperature Sensors Forum » Valid application of TMP75
Share
Temperature Sensors
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    DAC Essentials: What’s with all this glitch-ing?
    Posted 4 days ago
    by Tony Calabria
    When designing with a digital-to-analog converter (DAC), you...
    This amplifier doesn't exist...now what?! - Part 2
    Posted 6 days ago
    by Xavier Ramus
    In Part 1 of this post, we looked at the theory involved in making...
    Engineering the world through Analog
    Posted 11 days ago
    by Hagop Kozanian
    Our lives are surrounded by analog everywhere we go. That’s...
This question is answered
Travis Metcalf
Posted by Travis Metcalf
on Apr 08 2012 17:29 PM
Prodigy50 points
Can the TMP75, mounted above a heated surface, be used to detect when the surface becomes heated? The TMP75 plastic case and pins will all be heated by the rising hot air. Does the sensor only measure the difference in the temperature of the case and pins?
Thank you, Travis Metcalf
metcalfengineering@cox.net
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • John Caldwell
    Posted by John Caldwell
    on Apr 09 2012 12:39 PM
    Expert6655 points
    Hi Travis,
    The TMP75 actually reads out the temperature of its own die by measuring the change in the voltage drop across an on-chip diode. The main thermally conductive pathway to the die is the pins of the IC so you can consider the part to be thermally coupled to its local area of the PCB. Because this pathway is far more thermally conductive than the radiative or convective pathway from an adjacent surface, the local temperature of the PCB is really going to dominate the measurement. I believe the TMP006 would be a better candidate for your application as it is intended specifically for contactless measurements like the one you describe.
    John Caldwell
    Analog Applications Engineer
    PA Linear Apps
    Report Abuse
    • Reply
  • Travis Metcalf
    on Apr 09 2012 13:14 PM
    Prodigy50 points
    Thank you for your quick response, and suggestion to use the TMP006. I think because of the added difficulty in handling the TMP006, I will try the TMP75 first.
    Travis Metcalf
    Report Abuse
    • Reply
  • John Caldwell
    on Apr 09 2012 13:22 PM
    Verified Answer
    Verified by Travis Metcalf
    Expert6655 points
    I understand your concerns, the wafer chip-scale package does require additional care during assembly. In terms of using a local temp sensor to determine the temp of an adjacent surface, one process that we have recommended in the past is to set up the system to determine a "transfer function" between the adjacent surface and the temp sensor. This can be done by leaving the surface unheated and allowing the measured temperature of the TMP75 to stabilize, then heating the adjacent surface and comparing its actual temperature (measure with an RTD or thermocouple for prototyping purposes) to the TMP75's measured temperature. By taking data at several temperatures, you should be able to develop a function to calculate the temperature of the surface from the measured temperature at the TMP75. It is important to remember that air currents, other sources of heat, and many other variables will affect the overall accuracy of this approach.
    John Caldwell
    PA Linear Apps
    Report Abuse
    • Reply
  • Travis Metcalf
    on Apr 10 2012 17:16 PM
    Prodigy50 points
    Thank you for your suggestion. Since accuracy is not a big issue for my application, I think the TMP75 should work fine.
    Travis Metcalf
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
