• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Other Analog & Touch » Temperature Sensors » Temperature Sensors Forum » Problem with Low Byte during Read
Share
Temperature Sensors
  • Forum
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    RS-485 - Who says you can't teach an old dog new tricks?
    Posted 3 days ago
    by Neel Seshan
    Would you agree that RS-485 has turned out to be one of the most...
    Filter for thought
    Posted 4 days ago
    by Soufiane Bendaoud
    Have you ever wondered how engineers designed active filters...
    Let’s take this driver out for a spin
    Posted 10 days ago
    Before I suggest a suitable op amp to drive an ADC, I look at...
This question is answered
Ricardo Rey
Posted by Ricardo Rey
on Apr 14 2012 22:18 PM
Prodigy60 points
Hi!
I'm having a weird problem using the TMP102 sensor.
Basically, I cannot use floating-point operations with my application, so what I do to get the right temperature is this:
1) Interpret the 8 MSB as the integer part
2) Interpret the remaining 4 bits as the fraction portion of the number.
I just handle everything in the fraction portion as integers, and then print them accordingly (the decimal point is just part of the
print format; the numbers are integers)
So, I read the 2 bytes that the sensor sends, and print them in a hyperterminal.
The first byte is working fine (I have a thermometer to compare results). However, the remaining byte is acting strangely: it only prints values between 0 and 127.
Considering 127 = 0b01111111, I am losing part of my fraction portion (the range from 128 to 255).
Has something like this happening to anyone? Maybe I'm doing something wrong while reading?
Thanks in advance
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Chris Featherstone
    Posted by Chris Featherstone
    on Apr 16 2012 16:40 PM
    Expert5125 points
    Ricardo,
    It sounds like you have the right idea when reading the two bytes. My concern is that you are reading 127 = 0b01111111 in byte 2. As you stated this byte is used for the decimal value of the temperature reading. In 12-bit mode only the first four bits are used for the temperature reading while the last four bits are all zero. In 13-bit mode only the first five bits are used for the temperature reading while the last three bits are all zero.
    If I understand correctly you are reading the last byte as follows:
    Is it possible that this byte has been misinterpreted in software? Is it possible that the most significant byte and least significant byte have been mixed up? The first byte will be the most significant while the second byte will be the least significant.
    Chris Featherstone
    Linear Applications Engineer
    High Performance Linear and Sensing Products
    Phone: (520) 750-2432
    Chris Featherstone
    Linear Characterization Engineer
    High Performance Linear Products
    TMP102
    Report Abuse
    • Reply
  • Ricardo Rey
    on Apr 16 2012 19:25 PM
    Prodigy60 points
    Chris
    Thanks for your fast reply.
    I think I'm not quite getting what you're saying. As far as I understood, in 12-bit config I have data in D7-D4 in byte 2, while in 13-bit I also have D3; however, you
    said that in 12-bit I only have D7, D6 and D5. Maybe I'm understanding the datasheet wrong?
    However, let me explain the issue a little bit more.
    Let's say the measured temperature is 36.000 celsius. Then it starts rising (the fraction portion rises in multiples of 0.0625). I only print 3 decimal digits, so I get something like this:
    36.000
    36.062
    36.125
    36.187
    36.250
    36.312
    36.375
    36.437  -> This one is the problem. I get this 437 when the byte I'm reading is 127
    36.437
    36.437... (this value continues for a while)
    37.000
    Basically, it rises normally until I get to a fraction portion of 0.437, which is represented by 0111 (I just care about the 4 most significant bits from byte 2),
    but then it's stuck there, until it jumps to the next integer, which has a 0000 in that part.
    I don't really think I'm mixing the two bytes up, because the integer part is always right (as I said in my first question, I have a thermometer to compare results), and the
    fraction portion is also always right until that value I mentioned.
    As a side note, the only writing operation I'm doing to the sensor is writing the 00 address so that I read from the temperature sensor. Other than that I'm not
    messing with any other register.
    Report Abuse
    • Reply
    on Apr 17 2012 17:31 PM
    Expert5125 points
    Ricardo,
    Thank you for the clarification, as well as the correction. Note that I modified my response above, and sorry for the confusion. I haven't seen this happen before. If I understand correctly the issue isn't that you are reading 127 like I previously thought it is that the reading of the device is getting hung up at the fraction portion 0.437.
    Does this happen all the time? Let's say the temperature is 38oC and rises. Do you see this happening again at different temperatures consistently such as:
    38.312
    38.375
    38.437
    38.437
    38.437...
    38.000
    I will continue to investigate this issue.
    Chris Featherstone
    Report Abuse
    • Reply
  • Ricardo Rey
    on Apr 17 2012 18:58 PM
    Prodigy60 points
    Chris
    That's precisely what happens: the temperature hangs at 0.437 (which is equivalent to 0111xxx in byte 2. In my case I always get
    01111111 - the 127 I mentioned earlier - which still decodes to 0.437). And, indeed, it happens with every temperature I've measured.
    So, yeah, after many measurements with 0.437 in the fraction portion it jumps to the next integer, like this:
    38.437, 38.437... 39.000.
    Thanks again for the fast reply, and let's hope we can figure this out =D
    - Rick
    Report Abuse
    • Reply
  • Norman Wong
    Posted by Norman Wong
    on Apr 17 2012 19:41 PM
    Guru14920 points
    Perhaps you are losing the top most bit in each byte read somewhere in the I2C stack. Maybe try test with cold spray to cause a negative temp to see if most significant bit of byte 1 gets set. Or read the config register. Byte 2 should have the MSBit set.
    Report Abuse
    • Reply
    on Apr 18 2012 12:37 PM
    Expert5125 points
    Rick,
    I have checked the device with our EVM. Below is a screen shot of the Temperature Register.
    This results in 27.9375 (above are bits D15-D4). As shown above you can see that bits D3-D0 are zeros. This is in 12-bit mode. Is it possible to capture a screen shot of the I2C lines? This would be helpful to determine any noise on the lines, if the data is valid, or if the microcontroller is not handling the bits appropriately etc.
    Chris Featherstone
    Report Abuse
    • Reply
  • Ricardo Rey
    on Apr 18 2012 20:30 PM
    Prodigy60 points
    Chris
    Unfortunately I don't have the EVM, since I only bought the sensor, not a whole development kit.
    To debug, I'm printing the second byte to a hyperterminal, and when I get to a temperature of 0.437 or greater in the fraction portion, I always read a 0111 1111.
    I find it strange that I'm getting a 1 in the unused bits, since the datasheet says:
    "The unused bits in the Temperature Register always read '0' "
    Thanks for the support and for the fast replies.
    - Rick
    Report Abuse
    • Reply
    on Apr 19 2012 12:04 PM
    Verified Answer
    Verified by Ricardo Rey
    Expert5125 points
    Rick,
    Although you are getting ones in the unused bits I would still treat these as "don't care bits", as you have been doing. My check with the EVM was to see if I was able to replicate the issue. This sounds like a possible communication issue. If possible I would analyze the communication on an oscilloscope and look at the data when the temperature is above lets say
    T = 27.437oC. If we can rule out a communication error, then we can also look at the program flow. If you would like to post any scope shots I will be happy to analyze the data.
    Chris Featherstone
    Report Abuse
    • Reply
  • Ricardo Rey
    on Apr 24 2012 20:12 PM
    Prodigy60 points
    Chris
    Sorry for not answering sooner, I have been really busy this week.
    This weekend I'm going to make some tests using and oscilloscope, as well as some other device that uses I2C, to see
    if the problem is the communication.
    Thanks!
    - Rick
    Report Abuse
    • Reply
  • Ricardo Rey
    on Apr 30 2012 12:38 PM
    Prodigy60 points
    Chris
    Thank you very much for your help. I have already solved the problem =D
    For some reason, my I2C protocol was having a problem when reading the second byte (the first one was indeed fine, but from the second
    onward it was doing it wrong), that's why the integer part was fine, but the fraction portion was incorrect. I already made the changes to my I2C, and it
    is working just fine.
    Thanks again for all your help.
    - Rick
    Report Abuse
    • Reply
    on Apr 30 2012 14:54 PM
    Expert5125 points
    Rick,
    I am glad it is now working. Let me know if I can help with anything else.
    Chris Featherstone
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
