i am using four TMP103 sensors on the bus in continious conversion mode. Due to energy terms i would like to spread the starting times of the different sensors over one cycle.
The only sure start condition i read out of the datasheet is reset/powerup, but i would like to set the frequenz up to 1 or 4 hz.
Is the Sensor, after changing the frequence by setting cr0&cr1 immediately starting a conversion? Or is there another way to set the starting times?
Thank you very much for your help!
Matthias
