Do you know of any technical problem to use the TMP441
Hi Eli,
The circuit you sent looks good. Please make sure to have pull up resistors (10k) on the SDA and SCL lines. To achieve the best performance when using a remote junction temperature sensor there are a few best practices that are recommended:
The noise from the power supply should be kept low
Leakage path at the diode should be kept high (refer to figure 3 in the data sheet)
Parasitic capacitive coupling between DXP and DXN should be minimized
Noise pick up from other components (ie clocks, switching power supplies, etc) into DXP and DXN should be minimized
