Hi Team,
My customer is just looking for Sample program to operate TSC2007. I'm wandering if we can share the software ported in TAS1020B on the EVM though... Can I have the software?
Takashi Onawa
Hello Takashi-san
You can take a look to Reference firmware. Here you can find as it's performed the interface between TSC2007 and TAS1020B. I hope this helps you.
Best Regards
José Luis Figueroa
Application Engineer
Hi Jose,
my customer also design the TSC2007 device on their system and after checked the reference firmware, they feedback that the reference code has defined the RESET pin as below code, however, the TSC2007 device don't have the RESET pin, so customer want to ask product team what is this define purpose? and how to handle this RESET pin? Or can they just remove the RESET pin define?
Any suggestion from BU is very appreciated.
void tsc2007_reset(void)
unsigned int i;
PIO_Configure(reset_pin, PIO_LISTSIZE(reset_pin));
PIO_Clear(&pins[1]); //Set RESET Pin Low
for (i=0; i < 10000; i++);
PIO_Set(&pins[1]); //Set RESET Pin High again after a short delay
Arthur
Hi Jose,
customer also want to know if we have windows driver? Please advise. Thanks.
Arthur
Hi Jose,
Besides Wince5/6, do we have windows7 or windows10 device driver? Please advise. Thanks.
Arthur
Hi Jose,
do you mean the TSC2007 GUI for windows7, if so, we would like to provide it to customer to see if this GUI enough for them or not? So, please send to me for support customer. Thanks.
Arthur
Hi Arthur,
Attached the GUI for Windows 7. Please let me know if this one works.
2677.TSC2007 EVM SW Installer W7.zip
Best Regards
José Luis Figueroa
Hi Jose,
I downloaded it from the link and installed it. But the same problem happen as attached messages. Please help.
On the other hand, even if we solve this GUI problem, but what customer need is the Windows 7 driver for implementing the TSC2007 touch function on their system. So, they still need the windows7 software driver to activate the TSC2007 touch function. Please advise if we have any other solutions. Thanks.
Arthur
Hi Jose,
we tried to install the EVM SW installer on several PC system but the problem are the same as attached message below. So, can you please verify it on your PC system to see if you have the same problem? We also checked the device manager for the TSC EVM driver status, it shown the software driver are not install. Please check your system to see if you see this issue or not?
On the other side, have you tried to attach any touch screen panel on the EVM board? are there any function response to the GUI when you touching the touch screen panel? Please advise. Thanks.
Arthur
Hi Arthur
I have verified it on my PC with a touch screen attached to the EVM, and I didn't have any problem. Below you can see the driver status and GUI that they are working properly.
Have you tried to use another EVM in order to discard a possible issue with that?
Best Regards
José Luis Figueroa
Hi Jose,
please advise what is your OS version? And what is the NI-VISA USB device driver? can you please take picture to show how do you attach your touch screen panel on your EVM board? Also, since we don't have any touch screen panel here, can you please ship one touch screen panel to me for verify here?
Thanks.
Arthur
