• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Other Analog & Touch » Touch » Touch Forum » TSC2006
Share
Touch
  • Forum
  • E2E Wiki
Options
  • Subscribe via RSS
Check out
Analog Wire blog
  • $core_v2_blog.Current.Name
    How to determine the power at output of modulator from DAC back-off level
    Posted 1 day ago
    by Habeeb Ur Rahman Mohammed
    Customers often ask how they can determine the power at the output...
    DAC Essentials: What’s with all this glitch-ing?
    Posted 5 days ago
    by Tony Calabria
    When designing with a digital-to-analog converter (DAC), you...
    This amplifier doesn't exist...now what?! - Part 2
    Posted 7 days ago
    by Xavier Ramus
    In Part 1 of this post, we looked at the theory involved in making...
TSC2006
TSC2006
This question is answered
Teodor Neagoe
Posted by Teodor Neagoe
on Nov 28 2010 21:35 PM
Intellectual265 points
These questions have been posted by one of my customers a while ago. He never received an answer.
Here they are again:
The following questions are to help me to understand how behave the TSC2006 when  it’s throughput (batch delay) is faster than the rate at which the processor read the X/Y coordinates.   The Window CE driver that is available on the TI web site use the TSC2006 in that mode.
-          When the TSC2006 finish processing a new X/Y coordinate but the processor has not read the previous coordinate is the new coordinate overwrite the previous one?
-          When the processor read the previous X/Y coordinate after the TSC2006 has finish processing the new Y coordinate but not the new X coordinate is it guarantee the X and Y position the processor get come from the same conversion cycle?
-          When the processor read an X/Y coordinate at the exact same time the TSC2006 is updating its X and Y registers is the data the processor will get be valid?  Is it guarantee the X and Y position the processor get come from the same conversion cycle?  Is the content from X or Y register can be corrupted?
The following questions are regarding the test conditions for the VOH and for the VOL of the TSC2006.
-          In the data sheet, the test conditions say IOH and IOL are 2 TTL loads but I don't know what is a TLL load. What are the IOH and the IOL current for one TTL load?  Is the magnitude of IOH and IOL are the same?
-          There is no IBIS model for the TSC2006 but there is one for the TSC2008.  Is the IBIS model for the SDO and PINTDAV outputs of the TSC2008 can be use for the TSC2006.
      Teodor
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Tom Hendrick
    Posted by Tom Hendrick
    on Nov 30 2010 06:09 AM
    Verified Answer
    Verified by Anonymous
    Guru86375 points
    Hi Teodor,
    For IOH and IOL, one TTL unit load is defined as 40 µA for a logic 1 and -1.6 mA for a logic 0.  The IBIS model would be different, as the model is dependent on the actual package.  We will check with the modeling team to see when the IBIS model for the TSC2006 will be available.
    Tom
    Report Abuse
    • Reply
  • Teodor Neagoe
    on Dec 14 2010 09:13 AM
    Few more questions Tom:
    The TSC2006 will be powered from the 3.0 volts supply rail, the conversion clock will be programmed to 2 MHz and the resolution will be programmed to 12 bits.
    -          Setting the “ Power Not Down Control ” (PND0) to ‘0’ or to ‘1’ has any consequence on the resolution of the A/D converter ?
    -          If I set the “ Power Not Down Control ” (PND0) bit to ‘1’ and the “ Converter Function Select ” (C3-C0) bits to ‘0001’ (scan X and Y) is the A/D converter biasing circuitry will always be on ?
    -          Is it OK to set the “ Conversion Clock Control ” (CL1-CL0) bits to ‘01’ (2 MHz) when the SNSVDD power is 3.0 volts and the resolution is programmed to 12 bits ?
    -          Is it OK to set the “ Longer Sampling Mode ” (LSM) bit to ‘0’ when the SNSVDD power is 3.0 volts and the resolution is programmed to 12 bits ?
    -          Does the hardware RESET signal need to be a pulse?  I ask the question because the power on reset (POR) on our system start low (‘0’) and go high (‘1’) 800 millisecond after all supply rails are OK.  It’s not a pulse it’s a step with 800 millisecond of low time.
    -          Regarding my previous set of questions, can you please verify if the X and Y values are write protected during read access to prevent the case where one or the other value is from a different conversion cycle.
    Report Abuse
    • Reply
  • Wendy Fang
    Posted by Wendy Fang
    on Dec 14 2010 15:07 PM
    Genius9725 points
    I put my answers next your question in green below:
    Setting the “ Power Not Down Control ” (PND0) to ‘0’ or to ‘1’ has any consequence on the resolution of the A/D converter ?  No, PND0 has nothing to do with the resolution of the A/D converter.
    -          If I set the “ Power Not Down Control ” (PND0) bit to ‘1’ and the “ Converter Function Select ” (C3-C0) bits to ‘0001’ (scan X and Y) is the A/D converter biasing circuitry will always be on ?  If PND0 bit is set to "1" , the A/D converter biasing circuitry will always be on after each conversion.
    If Is it OK to set the “ Conversion Clock Control ” (CL1-CL0) bits to ‘01’ (2 MHz) when the SNSVDD power is 3.0 volts and the resolution is programmed to 12 bits ? Yes, it is fine.
    -          Is it OK to set the “ Longer Sampling Mode ” (LSM) bit to ‘0’ when the SNSVDD power is 3.0 volts and the resolution is programmed to 12 bits ? Yes, it is fine.
    -          Does the hardware RESET signal need to be a pulse?  I ask the question because the power on reset (POR) on our system start low (‘0’) and go high (‘1’) 800 millisecond after all supply rails are OK.  It’s not a pulse it’s a step with 800 millisecond of low time. Yes, it is an acceptable power up sequence.
    -          Regarding my previous set of questions, can you please verify if the X and Y values are write protected during read access to prevent the case where one or the other value is from a different conversion cycle. To make sure you read data in the same cycle, you need to check the /DAV status of the /PINTDAV pin. You may call me (214 567 4838) between 8:30am to 5:00pm CST weekday if you have further questions or need more explanations.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
