I am not using the evaluation software, but i am using a microcontroler with i2c to communicate with bq and I did already some writes and reads from flash I am using the bq34z100 and a I have a doubt about one of the steps to configure bq. In step 4, Determine the Sense Resistor Value, in the end is said that: The value of the current sense resistor should be entered into both CC Gain and CC Delta parameters in the Data Flash Calibration section of the Evaluation Software. In datasheet i see the position of this 2 registers in flash, but my doubt is what values i have to put in their, because i assume that is not just about put the value of resistor. My resistor is 1mOhm.
Can you help me?
