We also would like to have RE data of LM53635LQRNLTQ1.
And is there any way to go Spread Spectrum Mode with 24V Input Supply, since sometimes we are seeing RE failing in lower Frequencies around 30 to 50MHz
Ganesh
Ganesh
Thanks, Brani for your reply.
We are using the same part as part of the design. When we are doing RE compliance Testing for IEC-61000-6-3 we getting some peaks at 30.64MHz, 43.8MHz, around 47MHz. We do not have any clock source for this lower frequency in our board. We are suspecting the power supply on this,
We have tried Fixed PWM and Light load efficiency mode. But in both mode, we were able to see the similar radiations.
1) Please share us the RE report of LM53635-Q1
2) Share us the way how we can reduce the peaks at the lower frequency when using LM53635-Q1 in design
Ganesh
