  • TI Thinks Resolved
TPS54360: Vcomp Noise level
Part Number: TPS54360
Is there any guide or recommendation about Vcomp noise level? like as its ripple voltage must be under 10% of Vcomp?
Nicky
  • Nicky,
    I do not know of a guide for this. Good layout and reasonable component selection should mean this is not an issue.
    -Sam
  • In reply to Samuel Jaffe:
    Hi Sam,
    That means there is no guide or recommended value about Vcomp noise?
    Just recommended to use reasonable component selection and layout. Am I right?
    Nicky
  • In reply to Nicky Lim:
    Nicky,
    That is correct.
    The COMP pin is connected directly to the output of an op amp so this is a low-impedance path. FB is a high-impedance, noise-sensitive pin which is right next to COMP. This is why we are more worried about FB vs COMP. If there's an issue with noise on COMP, there's almost definitely a bigger issue with noise on FB.
    -Sam
    Hi Samuel,
    I Have a design that could take an experts eye. Can you pass me your mail so that I can send you the Gerbers.
    Thanks ,
    Tony
  • In reply to Tony Philip69:
    Tony,
    Send it to my email. I'll take a look. Thanks,
    -Sam
