Hi All,
I have an Project Where TLC 5958 driver IC is used to drive the 16x48 LED Board.16x48 Board will be used to display English alphabets . Each OUT channel of TLC5958 IC is used to control 1 column of the 16x48 matrix board . All the function of IC(Brightness Control etc. ) is working properly still I am facing following issues while trying to control OUT channels.
1. When I send GS data ={0xFFFF,0xFFFF,0x0000} 16 times to fill the 16 channels (the default configuration of function Register is used that uses 1 Scan line.) The OUTR0 - OUTR14 channels will be turned off. that is perfect. whereas when the GSdata is={0xFFFF,0xFFFF,0xFF00} the OUTR0-OUTR8 channels are supposed to be turned off but all OUT channels is on .
Please help me to find the solution of this problem .
I am also attaching my code and the semitics for detailed information.
Thanks.
with Regards,
Mayank.
