  • Resolved
BQ78350: Overcharge Protection is detected in my gauge, but the remaining capacity and the full charge capacity are the same.
Intellectual 550 points
Part Number: BQ78350
In the user manual,  I  notice that the OC protection is tripped when the remaining capacity >= the  full charge capacity + OC : threshold.
The parameter, OC  threshold , is default.
But the remaining capacity and the  full charge capacity are the same in the  bqstudio.
Why?
  • hi Feiyue,
    I wanted to let you know that your post has been assigned to one of our applications engineers. This week takes place our annual Battery Management Deep Dive event for which all our engineers are all hands on deck. He will be able to your post early next week, once this event is over.
    You can check out recordings of much of the material we present at www.ti.com/deepdive
    Thank you for your understanding!
    David
    TI provides design resources and design advice (including technical, schematic, code and/or system review) “as is” and with all faults.  All information in this or related correspondence is provided subject to TI’s Important Notice
  • Hi Feiyue,
    Remaining Capacity will never report higher than Full Charge Capacity in the device registers. However, internally it is tracked to higher values to protect against over charge.
    Matt
  • In reply to Matt Sunna:
    Thanks a lot, I understand it.
