Dears:
There will happen power off and the waveform as follows:
Verifying the 25W load ( using the cement resistor), running for a period of time (such as a few hours), there is no power failure problem, during this period may be overloaded. This time take off the load, and the device is then powered normally. In this case, the device has only the device (5W), but the problem happened.
1. PSE side waveform:
