  • Resolved
TPS61194: about SYNC and PWM
Mastermind 6280 points
Part Number: TPS61194
Hello E2E,
Our customer is adjusting the signal input timing on engineering board.
Please let me know about SYNC and PWM.
 -1-  When the phase 36-deg, why occur negative spike on SW-pin?
 -2-  Does this device have a recommended dondition or input phase for SYNC and PWM?
ACGUY
negative spike.pdf
  • Hey E2E,
    Please help me!!!!
  • In reply to ACGUY:
    Hi ACGUY,
    I'm sorry for the late response. What you 'SYNC" frequency and waht's your PWM frequency? And in which situation you find this situation? And how you control the phase bethween "SYNC" and "PWM". I have talked with our designer, it seems those are two different parts. We don't have strict requiremnet about the phase. You can also observe the inductor current. Is there any difference on the inductor current? Thanks.
    Sean
  • In reply to Sean Zhou:
    Hello Sean,
    -> This is for automotive application. SYNC is provided from MCU. Frequency synchronize is for EMC.
    -> The designer intends to make EN high at an arbitrary timing. However, Negative Spike occurs in the SW - pin, which exceeds the absolute maximum rating. Negative Spike has correlation with SYNC and EN.
    -> I will check with the designer and reply at a later date.
    ACGUY
    Hi ACGUY,
    What's the frequency to "SYNC" pin and what's the frequency to "PWM" pin?
    Sean
    Hi sean,
    PWM is about 200-Hz. SYNC is 2-MHz. I got inductor current waveform.
    Please let me know your opinion.
    ACGUY
    Neg-spike_2.pdf
    Hi ACGUY,
    The inductor current waveform seems stable, I have aligned with our designer, he thought that those two frequency will flow to different parts and boost swithing frequency is very high, the pwm dimming is very low, it should has litle effects on the boost performance. To be honest, I don't have much ideal on this phenomenon. Do you find same phenomenon on different parts? Have you tried any other frequency? And dose those spike has any infulence on your performance? or EMC performance?
    Sean
    Hi Sean,
    No. This negative spike is over the absolute max ratings for this device.
    But, If you say "no problem", we will relieved.
    Not yet. I will suggest it to our designer.
    ACGUY
    Hello Sean,
    Do you have any update information about this topic?
    ACGUY
    Hi ACGUY,
    I'm sorry that I don't have much update information about this topic. As I have said before:"Do you find same phenomenon on different parts? Have you tried any other frequency?"
    Sean
    Hi Sean,
    Yes. this phenomenon is reproduce at other same device.
    Yes. However, negative spike was not disappear.
    (The phase difference at which a negative spike occurs is different.)
    Why does a negative spike occur due to the phase difference between PWM and SYNC?
    ACGUY
