Hi Team,
On TPS25927x data sheet page 5, it indicates the MIN and MAX value of Overload Current Limit.
I would like to learn from you how we got the value of Overload Current Limit MIN and MAX value?
Thank you.
Hi Team,
Thank you.
Hi Tiffany Liu,
The major factor which contributes to the Variation of Overload Current limit is the 'Offset of the Internal Amplifier' as highlighted in the block diagram below. That is the reason why the variation % increases at lower current limits.
Generally, we test a certain number of samples from different lots , across temperature and see the variation of the parameter. Then we add some guard band and define Min and Max values. in Production, all the IC's are tested for that parameter and any IC which has that parameter out of Min, Max values are rejected.
Hi Praveen,
May we learn from you how to calculate the error of Overload Current Limit?
Or no calculation but just based on data sheet Figure 20?
Please advise. Thank you.
Tiffany
