Hi Team,
The LM25066A is an ideal 12V hotswap solution for the use in server platforms, usually two external power MOSFETs (i.e. 5x6mm package) are used in parallel in our design to handle 12V main power for the system, since the power supplied by 12V main has increased constantly on new platforms because of instaneous peak power in turbo mode, I would know is there any limitation for the LM25066A to connect more MOSFETs in parallel for higher power delivery? Or any other solution is suggested.
Eric
