I found a question regarding input voltage of the TPS76901-HT in the portal, however it did not have any answer.
The 125C component TPS76901 has recommended input voltage range of 2.7-10V, whereas the TPS76901-HT version has recommended input voltage range of 5-10V.
What is the difference between these components?
Can TPS76901-HT be powered by voltage lower than 5V, for example 3.5V?
Thanks!
