Other Parts Discussed in Thread: TPIC7218
software will 0X12 Register wirte only once, but activate TPIC7218 ,the 0x12 Register will change in operation, pls help advise resolve the problem.
Hello Chai,
I'd like to help you with this issue. I have a few questions about your problem. Register 0x12 contains multiple fields. Which register bits in 0x12 are you writing to change from their defaults? Which bits are getting changed later? Are they changing back to the default?
Are you using the Watchdog, and if so, have you confirmed there are no watchdog failures? A watchdog failure may clear some SPI bits in certain cases.
thanks,
Ben
