Now trying to program to read COMM pin Bit Pattern, but it does Not work.
And furthermore, since we do NOT use dimming function, we keep pulling high both DIM1 and DIM2 pin.
Our programming procedure is as followings;
Power on.
Confirm the power-good indication.
=== To read COMM pin’s BIT PATTERN ===
Pull EN pin low about 200 n-sec to reset, then pull EN pin high.
Pull COMM pin low 4 times by external MCU to read COMM pin Bit Pattern.
=== Result ===
The COMM pin remains High. Bit Pattern is NOT output on COMM pin.
My question is,
Are there any other procedures what we need to check or set coding?
