Could you please suggest a standalone battery charger IC to charge Tadiran battery (TLI-1020A). The recommended charging voltage and current for the battery are 4.1 V and 8 mA respectively.
Thanks.
Thanks.
Neeharika,
I failed to notice that the BQ25100L is in product preview and currently not orderable. It appears the BQ25150 is your only option. The BQ25150EVM has downloadable software that can be used with an EV2400 to control the BQ25150.
Jeff
Great! Just curious how you found it. I did a search on the website for 4.1V and low current regulation but this did not show up. I need to get our website search improved.
Jeff
The BQ25100 is still a good choice. If you don't intend to use the TS feature on the charger, you can set the NTC to warm by connecting a 4.8K resistor to TS which sets the VBATREG voltage to 4.06V.
