Hi All,
My customer for a telemetry application for motorsport is looking for a step up (no Q100 required) with the following specs:
Vin 5Vusb; Vout 10-15V; Iout 1-2A; Pout 0.5-4W
Do you have any proposal here?
Many Thanks,
Antonio
Hi All,
Many Thanks,
Antonio
Dear Sir,
Does the input current need to be limited?
The input is 5V from USB, I am not sure if it can be limited.
In case it must be limited what is your proposal?
Many Thanks,
Antonio
So the input is limited. USB usually limits the current at 0.5A, or 1A, or 3A depending on which spec it follows.
I just found your spec does not make sense. If Vout =10-15V; and Iout=1-2A; the Pout would be 30W max. Not sure how do you get 0.5 to 4W. Is the load current a typo?
Could you clarify?
Youhao
