• TI Thinks Resolved
BQ27220: How to calibration BQ27220 with few parameters
Expert 2870 points
Part Number: BQ27220
hi Onyx,
Further question to BQ27220 configuration. my end customer has completed the fuel gauge training and they observed the missing configuration are as follow:
so far, they have managed to write to the design capacity and EDV0,1,2 correctly. Need to know how to write the Calibration parameters: board offset(integer) , CC offset(integer) , CC gain (floating value), CC Delta (floating value) into the register. can you advice the steps? Hope you can provide the clear steps to spped up the troubleshooting.
Note: End cust do not want to write to OTP but only want to configure the register everytime the MCU boot up to save time and manufacturing process.
KPK
  • hi KPK
    The calibration parameters are df parameters just like the design capacity. Writing to those registers is the same steps.
    For floating points, you will find e2e post below useful.
    https://e2e.ti.com/support/power-management/f/196/p/313974/1546093#1546093
    thanks
    Onyx
  • In reply to Onyx Ahiakwo:
    hi Onyx,
    Will you be able to help to convert the following into hex value for below parameters that the fuel gauge can understand?
    Below are decimal values.
    Paramters New Value
    Calibration / Current / CC Gain (F4) 0.1766
    Calibration / Current / CC Delta (F4) 210650
    kpk
  • In reply to Poh Kok Keng:
    Pls follow the instructions in the post provided.
    thanks
    Onyx
