Other Parts Discussed in Thread: BQ24040,
Our design uses BQ51050B for wireless charging and also BQ24040 for wired charging. Battery is LiPo, 500 mAh
We also have a fuel gauge which is On Semi LC709203FQH-01TWG.
Both charging methods work fine. Problem is that during charging the fuel gauge always reads 100%, because the fuel gauge detects the charging voltage and thinks the battery is fully charged.
One way to work around this limitation would be to temporarily interrupt charging, allowing the fuel gauge to accurately measure the battery level.
Is there a way to halt the charging on BQ51050B without causing a disconnect? Can TS/CTRL be used for this function?
