HELLO!
I don't quite understand how this circuit is designed and how comm pins communicate.
Best regards from China,
Zhetao Xie
HELLO!
Zhetao Xie
Hello
The external Comm circuit will only prepare the signal before it is applied to ADC of the BQ500211.
Diode network is a protection circuit, limit voltage between gnd and 3.3V.
R14 / R5 is a voltage divider to bias the signal to ab to 1.5V.
R6 / R5 is a voltage divider to reduce signal amplitude.
C18 will couple the AC portion of signal to R6 / R5 network.
C14 is high freq filter.
Note that the portion comm signal (tank voltage) used is the lower part and will be between ground and 2.5V at R5.
