• TI Thinks Resolved
TPS54561: use bias voltage on boot pin
Intellectual 1160 points
Part Number: TPS54561
Hi Team,
just want to check with you if adding a 5.4V bias voltage on Boot pin through a diode is OK for normal operation or not.
The 5.4V power up before Vin and shut down before Vin.  Thanks.
BRs
Given
    I think that should be ok, but just be aware of the maximum boot voltage limit for the pin
    I can see that there is an app note similar to what you are trying to do
    http://www.ti.com/lit/an/slva547a/slva547a.pdf
    I would say that you should power the 5.4V up after you power the VIN
    -Arief
  • In reply to Arief Hernadi:
    Hi Arief,
    Thanks for your reply.
    one more question, why does the 5.4V up after Vin? It seems no difference from my perspective. Thanks.
    BRs
    Given
  • In reply to Given Ding:
    Hi Arief,
    Any feedback? Thanks.
    BRs
    Given
    Hi Given,
    For me it is just a precaution so that the external bias does not interfere with normal startup sequence of the IC.
    -Arief
    I believe Arief was able to help you out here.
    Let us know if this design requires more help.
    Marshall Beck
    Texas Instruments, Power Applications
    If this response answered your questions/concerns, please click Verify Answer below.
