I am debugging a legacy design where we have the ctrl signal connected to 1.8V, VIN - 5V and rest of the circuit follows your recommended schematic as shown below. Previously, I was measuring 0V at the output but then that was caused by the reverse polarity of the Diode on CTRL pin and after fixing that issue, I am measuing the correct voltage on ctrl pin. I am not sure what might be causing the voltage drop from required voltage to zero. Any recommendations on what might be causing this issue?
Ranga
