We are using BQ29700 for protecting a single cell Li-ion battery. The schematic is attached. In the datasheet, I have found that the different protection are based on the different voltage level on COUT, DOUT, BAT pins. So, Can I connect them to the controller pins/LED to monitor the different faults in the battery? If yes, can you provide me some information about the tentative connections from the IC to controller/LED.
Thanks.
