I have the Eval board, special cable and the GUI app. I have replaced the Eval board with my intended development target, the BQ76PL455A-Q1 chip integrated into a PCBA.
I have a system setup and everything works fine with the GUI. I can easily configure, control, monitor and log anything on my target using this panel, but only using a manual method. I'd like to automate this using LabVIEW (or other) if possible.
I noticed in your user guide: "sluuba7a.pdf" you mention a command/response test flow from the GUI to the target.
Can I obtain this C/R API for the function calls, comm session-establishment steps, data acquisition steps, etc.. from the target? (we're buying many of these targets BTW)
I'm building a larger system that will test multiple targets and it would be impractical to do this manually through the GUI unless there is something I'm missing with this app.
Thank you,
