• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Battery Management » Battery Management - Chargers Forum » BQ24171 EVM
Share
Battery Management
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
BQ24171 EVM
BQ24171 EVM
This question is answered
Alexander Dobranich
Posted by Alexander Dobranich
on Mar 28 2012 09:17 AM
Prodigy30 points
I am using the BQ24171 EVM to charge and protect a single Li-ion cell. I have been able to discharge through the BMS, but It does not seem to be protecting the battery from over discharging. I have also been unable to recharge a battery, even one that is only discharged to 3.2V
The settings I am using are:
JP1: internal-TS
JP2: closed
JP3: Open
JP4: closed
I have no temperature sensor attached to the external sensor. I am discharging through a 5Ohm power resistor and and have been providing external power at five volts (no power transfer) and at 10V (power transfer but no detectable charging.)
Any advice would be appreciated. Thank you.
BQ24171 EVM
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Tahar Allag
    Posted by Tahar Allag
    on Mar 28 2012 09:52 AM
    Genius13910 points
    Alexander,
     If the temperature sensing is not needed, please disable it by putting a JP1 on “int”. Please follow the test procedure on the user’s guide for proper jumper set up.
     http://www.ti.com/product/BQ24171
     -Tahar
    Report Abuse
    • Reply
  • Alexander Dobranich
    on Apr 03 2012 19:26 PM
    Prodigy30 points
    I have performed the test, however it failed to meet specifications,  right out of the box.
     Note: In 2.5.2 the test is declaring Load#1 and Load#2, it has them interchanged. The device that can control its voltage and current requirements is simulating the battery, not the system load.
    Note: In  The test says "Connect 2-3 of JP1 (Internal TS);" but Internal and TS are pins 1-2
    On to my test, when performing 2.7.1 It passed, but I note that for VBAT and REGN My voltage was almost zero, which is within the specs, but suspiciously so.
    However the test failed in 2.7.2 VBAT and REGN were both .7V instead of the 6V and 4.2V expected (I am using the 001) so that step failed.
    In 2.7.3 The addition of a constant voltage source to the system failed to produce any response in the system.
    Please Advise. I bought another EVM to insure I had not merely broken the first one, but they both perform identically.
    BQ 24171 EVM
    Report Abuse
    • Reply
  • Tahar Allag
    on Apr 04 2012 10:53 AM
    Genius13910 points
    We are verifying these steps in the lab.
    Report Abuse
    • Reply
  • Tahar Allag
    on Apr 04 2012 12:31 PM
    Verified Answer
    Verified by Tahar Allag
    Genius13910 points
    We verified the step in the lab, they worked as expect for us. Yes, there is a typo in the TS pin setup in the user’s guide, but that should not affect any thing regarding the functionality of the EVM. Also it is very well labeled in the EVM (Internal and External).
     Make sure you are using power supply with enough current limits and an electronic load.
    Report Abuse
    • Reply
  • Tahar Allag
    on Apr 04 2012 16:18 PM
    Genius13910 points
    Table 5 provides the assembly number and the text of the EVM.
     The bq24172/1EVM-706-15V is used for 3 cells.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
