• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Battery Management » Battery Management - Chargers Forum » Using BQ2954
Share
Battery Management
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
Using BQ2954
Using BQ2954
This question is not answered
boon seong thng
Posted by boon seong thng
on Apr 05 2012 23:52 PM
Prodigy70 points
I am currently doing a project where I’m developing a LiFePO4 battery charger to charge 4 of these cells in series. I am using the bq2954 IC and the circuit that I have implemented is found in the “Using BQ2954” application notes as follows:
http://www.ti.com/general/docs/lit/getliterature.tsp?literatureNumber=slua447&fileType=pdf
The calculations for the above circuit are done using the formulas in the “bq2954 Datasheet” as follows:
http://www.google.com.sg/url?sa=t&rct=j&q=bq2954%20datahee&source=web&cd=1&ved=0CDcQFjAA&url=http%3A%2F%2Fwww.datasheetcatalog.org%2Fdatasheet%2Ftexasinstruments%2Fbq2954.pdf&ei=mnl9T7r2N8HnrAfqmZXbDA&usg=AFQjCNEB4Ghk6zUa22q0_-PRIg0StpQJ6g&cad=rja
As can be seen from the ‘datasheet’ of the bq2954 IC, the Charge Current (Icharge), to charge the battery pack (4 cells in series, in this case), is determined by the Rsns (Current Sense Resistor). Thus, using the formula “Rsns = Vsns/Icharge” which comes to “Rsns = 0.25V/Icharge”, I set my charging current (Icharge) as 5A, so the Rsns value comes to 50 mohms.
However, the problem that I am facing is that even with this value of Rsns, I cannot get my Icharge as 5A. It is only showing as arnd 200mA, which causes the charging to take place, but very slowly.
Could someone please help me out? How can I solve this problem and increase my Charge Current (Icharge) ?
Thanks a lot! :]
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Charles Mauney
    Posted by Charles Mauney
    on Apr 09 2012 11:22 AM
    Mastermind25215 points
    I need more information and maybe some waveforms of each pin of the IC.
    Is the input voltage at least 18VDC?
    Is the battery at least 12.4V?  If below ~12V the charger will be in precharge and one gets 1/10 the current.
    I would suggest using a newer IC, like the bq24600 or '610.
    Report Abuse
    • Reply
  • boon seong thng
    on Apr 10 2012 08:15 AM
    Prodigy70 points
    Hi Charles,
    Thanks a lot for your reply.  As you have requested, the following is the info to add on to what I provided earlier.
    1) We are connecting 4 cells in series, total battery pack voltage for the 4 cells is arnd 13.2V (arnd 3.3V per cell).
    2) The Vin we are providing is 17V. We have observed that providing anything more than this 17V for 4 cells in series, causes the bq2954 IC to show fault condition.
    3) The reason we can't use a new IC as you suggested is because, this is our Final Year Project, and it ends this month by the end of April. Thus we do not have enough time on our hand to implement a new circuit. So, since we have been researching and working on this bq2954 IC, we have almost got everything correct except this charging current. Thus,we hope to identify and rectify the problem with this IC itself, given the lack of time.
    Some more info on our circuit when its charging the cells:
    • Our bq2954 charger circuit is working on mode 3 (as set by the DSEL pin)
    • Our Iterm pin has been left floating, which sets Ifull as (Imax/15) and Imin as (Imax/20)
    • When our battery is connected and the circuit is switched on the following is our LED statuses:
    LED 1: ON
    LED 2: OFF
    CHG pin LED: OFF
    BTST pin LED: OFF
    • And when our switched on but the battery is not connected, the following is our LED statuses:
    LED 1: OFF
    LED 2: OFF
    CHG pin LED: ON
    BTST pin LED: ON
    • When we supply the 17V input for the 7cells series, the current meter shows only around 120 to 130mA.
    I shall be posting the waveforms at the different pins of our IC by tmr morning. Till then, thanks a lot for your help and advice. Looking forward to hearing from you.
    PS: Do let me know if you would like any other info abt our circuit.
    battery charging battery Charger BQ2954 Charging Li-Ion battery charger Battery Chargers battery management LiFePO4 li ion battery charger
    Report Abuse
    • Reply
  • Charles Mauney
    on Apr 10 2012 14:40 PM
    the LEDs seem normal except for the BTST..does ON mean high or low?
    Battery test output: Driven high in the absence of a battery in order to provide a potential at the battery terminal when no battery is present.
    You indicate initially 4 cells and then 7 cells, which is it and what chemistry?
    If you are getting 120 t 130mA and expecting 5A I think you have something seriously wrong.  What is the voltage across the sense resistor?
    is your battery return floating with respect to ground.
    Do you have a schematic?
    Report Abuse
    • Reply
  • boon seong thng
    on Apr 10 2012 23:02 PM
    Prodigy70 points
    For the LEDS,
    1) BTST led on means: BTST pin from the IC is high.
        CHG led on means: CHG pin from the IC is low.
    2) I'm sorry, that was a mistake, it is 4 LiFePO4 cells in series.
    3) The voltage across our current sense resistor (0.05ohms) is 12.5mV. The datasheet of our current sense resistor is as follows:
    8407.50mohm Resistor.pdf
    4) the battery return means the feedback from the voltage divider circuit right? the one that connects to BAT pin on the IC? It has been connected, it is not floating.
    5) The following is the schematic of our circuit:
    Thanks a lot. Do let me know if u need any other info.
    battery charging battery monitor battery Charger BQ2954 Charging Li-Ion Battery Chargers Charge Current battery management LiFePO4 li ion battery charger
    Report Abuse
    • Reply
  • boon seong thng
    on Apr 11 2012 00:07 AM
    Prodigy70 points
    The following are the waveforms at the various IC pins of bq2954 and the power mosfet Q5 in our circuit (All waveforms taken CH2 on oscilloscope):
    MOD waveform at pin 14 of IC:
    TS waveform at pin 8 of IC:
    SNS waveform at pin 7 of IC:
    BAT waveform at pin 3 of IC:
    Waveform at Drain pin of Q5 power mosfet:
    Waveform at Gate pin of Q5 power mosfet:
    Thanks. Do let me know if u need waveforms at other pins of the IC bq2954.
    battery charging battery monitor battery Charger BQ2954 Charging Li-Ion battery charger Battery Chargers Charge Current battery management LiFePO4 li ion battery charger
    Report Abuse
    • Reply
  • boon seong thng
    on Apr 11 2012 21:09 PM
    Prodigy70 points
    Hi Charles,
    Any updates based on my circuit schematic and the waveforms I posted?
    PS: We are using a breadboard to test our charger circuit, specifications for which are as follows:
    breadboard project gl 12
    Will that cause any problems to the charge current? (current limitation? etc...)
    Boon Seong
    Report Abuse
    • Reply
  • Charles Mauney
    on Apr 12 2012 11:31 AM
    Thanks for the waveforms they are informative.
    1) The TS pin looks like it is close to the cold fault threshold (3V) if you are using a 5V Vcc on the IC.  Why is this not more in the center of the TS range.
    2) The SNS pin photo is taken a 2V/div and does not show good resolution...should use 0.2V/div.
    3) The BAT pin also has poor resolution and looks like it is close to regulation at 2.05V...if the cell is at 13V then the pin should be 13/14.76*2.05 = 1.8V.
    4) don't understand why there is not ~250mV at the sense pin.
    5) I found the problem (just thought of it)......search the data sheet for "80".  You will find several places where the maximum duty cycle is 80%, so to get 14.76V out with 80% maximum duty cycle one would have to have 14.76/0.8 = 18.45V input plus about 1V of head room, so I would recomment 20V minimum input.
    If you can't specify a 20V or greater supply, then I would switch to another IC.
    Report Abuse
    • Reply
  • boon seong thng
    on Apr 12 2012 21:08 PM
    Prodigy70 points
    I see, is using the breadboard causing any problems?
    Report Abuse
    • Reply
  • boon seong thng
    on Apr 19 2012 03:52 AM
    Prodigy70 points
    Hi Charles,
    We have fabricated our entire circuit, and completed it connecting all the components.
    1) The TS voltage is around 2.3-2.4V, which is well between the operating threshold.
    2) The SNS pin is showing 13.6mV, not 250mV.
    3) The BAT pin has voltage of 1.86V.
    The input current at the power supply shows arnd 260mA. We are also supplying arnd 20V+ to the input..
    So do you know why the charge current problem is still persisting?
    Report Abuse
    • Reply
  • Charles Mauney
    on May 01 2012 07:44 AM
    What is the voltage at the switching node and duty cycle.
    What is the battery voltage?
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
