Details of the available packages are given under "Mechanical Data" at the end of the datasheet.
You have to add the part in Eagle Library using these dimensions. Symbol also needs to be entered in the schematic library
JayantD.
Hi and thanks for your answer,
In the datasheet of bq24210 there are only size specifications of the IC, but there aren't specifications about the PCB layout. If there isn't a eagle cad library, I believe that the size specifications of pads layout are necessary in order to design an appropriate PCB!Is there anyone that made a PCB with the bq24210 IC?Is there anyone that know eagle cad library for bq24210 IC?Is there anyone that already made PCB layout of pads for bq24210 IC?
Giuseppe
I already read this guidelines, but in my opinion they are too generals. There is only one general example board layout (page 12). I don't know if I can use these specification for bq24210 board layout, who does it ensure this to me? Moreover, what is the right way to design the thermal pad? The example in these guidelines regarding an IC too different than bq24210.I have still my problem!
A google search came out with the following links:
http://www.ti.com/lit/an/sloa122/sloa122.pdf
http://www.freescale.com/files/rf_if/doc/app_note/AN3778.pdf
http://www.intersil.com/data/tb/TB389.pdf
This should give you an idea about how to proceed.
Giuseppe Suriani The example in these guidelines regarding an IC too different than bq24210.I have still my problem!
In case you are expecting someone to upload a readymade eagle library, then I'm sorry,..!
JayantD
Thanks for your availability
Hi Giuseppe, PCB for bq24210 you can found in FARNEL online catalog.
Svetlo
Jayant Deshpande Hi, A google search came out with the following links: http://www.ti.com/lit/an/sloa122/sloa122.pdf http://www.freescale.com/files/rf_if/doc/app_note/AN3778.pdf http://www.intersil.com/data/tb/TB389.pdf This should give you an idea about how to proceed. Giuseppe Suriani The example in these guidelines regarding an IC too different than bq24210.I have still my problem! In case you are expecting someone to upload a readymade eagle library, then I'm sorry,..! Regards, JayantD
I was just browsing for relevant posts for my pcb assembly project and I happened to stumble upon yours. Thanks for the informative links!
dave
