• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Battery Management » Battery Management - Chargers Forum » BQ24103A - Only works with at least 14V VIN.
Share
Battery Management
  • Forums
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Carl-Johan Sjoberg
Posted by Carl-Johan Sjoberg
on Apr 25 2012 07:21 AM
Prodigy30 points
BatteryManagement.pdf
We've a design with the BQ24103A, please see attached pdf for schematic.
The problem we have is that it sometimes works like a charm and sometimes it enters some linear mode drawing between 30mA to 250mA on the 12V rail.
Especially when the cell voltage is low. The voltage is clamped to the cell voltage.
In order to get it working I need to crank up the VIN voltage to 13-14V and it will start battery detect mode. It doesn't matter if the CELL pin is pulled low or high.
Vbat will be approx. 12.5V.
On the schematic Vchg is 12V. Vbat should be 8.4V, 2 cells mode. LiPoly cells has built-in protection.
All our prototype boards have this symptom. I've scoped all inputs with a 100MHz/2GS oscilloscope and all signals are clean and I've checked the marking on the chip and it's CKO and from the same reel.
I've fiddled around with different inductors and Cout caps but the same result.
I'm a bit confused now so maybe a TI engineer can give hints/suggestion to fix this or/and explanation of the this behavior.
Gerber and PCB from Altium Designer can be sent to a private email.
And a last question, what is the difference between BQ24103 and BQ24103A? Because of 2008 there is no need for a Zener on neither of them.
Kindly Regards,
Carl-Johan Sjoberg
BQ24103A Overvoltage Unstable 2-cells 8.4V
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Wang5577
    Posted by Wang5577
    on Apr 27 2012 10:41 AM
    Genius12450 points
    So far, I don't find the problem on the schematic. But, I don't know your test condition also. Let me summarize your test condtion. And please give more info.
    1. Vin=12V, input current is about 30mA~250mA. What is the battery voltage? Is it lower  than pre-charge threshold?
    2. When Vin=13V~14V, Vbat will be approx. 12.5V. This is not right. Does IC get damage or bad soldering?
    bq24103 is pin to pin compatible as bq24103A. The performance should be same. They both don't need a zener after 2008.
    Report Abuse
    • Reply
  • Carl-Johan Sjoberg
    on Apr 30 2012 05:42 AM
    Prodigy30 points
    We've tracked down a couple of issues.
    1. Suspecting transients on VCC that breaks the internal LDO. VTSB is either ~9V or 0.7V.
    2. Suspecting transients on PG, STAT1 and STAT2 as these pins are not pulled up during initial testing.
    I'll swap the BQ chip and pull-up PG,STAT1 and STAT2. Also I'll add a 15V Zener to VIN and VCC.
    If we have the batteries connect they will clamp the voltage and after a while the over-voltage protection in the batteries will disconnect the batteries.
    First step in testing is to apply +12V and see that we've pulsing on OUT pin. Battery detection.
    Second is to check wave form on Cttc.
    After that we connect the batteries. Usually around ~7V.
    Charging begins and everything is ok.
    Next step is to remove the +12V and remove the batteries and do the testing again.
    After this step all our BQs broke. So we suspect that transients is the problem.
    I'll let you know the outcome of the tests.
    cjs
    Report Abuse
    • Reply
    on May 08 2012 11:08 AM
    Verified Answer
    Verified by Carl-Johan Sjoberg
    Prodigy30 points
    I added a BZX84C15 diode, 15V zener to VIN/VCC, made sure that PG, STAT1 and STAT2 is always pulled up and swapped the 27uH inductor to a 22uH to increase the margin to Isat.
    Now it works as expected.
    cjs
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
