• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Battery Management » Battery Management - Chargers Forum » BQ24003 offsetting voltage drop for long Vsense wire
Share
Battery Management
  • Forums
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
darrell kirby
Posted by darrell kirby
on Apr 30 2012 14:08 PM
Prodigy20 points
i am trying to overcome a large voltage drop on the vsense pin of the bq24003. my charge cable has to be a minimum length of 25 feet. i am gettingabout .08 amp loss and about .4 volt drop. is there a resistor i can change on the eval board to compensate for this drop? also, is there any way to change the bi-color LED state to "off" when charge is complete?
Thanx
darrell kirby
darrell@kirbysite.net
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Charles Mauney
    Posted by Charles Mauney
    on Apr 30 2012 14:21 PM
    Verified Answer
    Verified by darrell kirby
    Mastermind25055 points
    There is a sense pin on that part that allows the battery to be connected to Vsense.  This would cancel out the drop from OUT to the battery but does not cancel out the return drop.
    You can put a divider in the feedback to the sense pin to boost the output voltage, but the issue here is that when the IC goes into voltage regulation the current tapers off and the IR drop is less which not the boost voltage is too high.
    Since the current does taper, the battery should still get full, it just rolls off the fast charge CC phase a little.  This should not be a big deal unless charge time is a factor.
    This part is set up to continue to charge for ~23 minutes after the LEDs have changed state.  The cell is considered full once the STAT1 goes high, but is like a top off mode over the next 23 minutes.  The user typically does not know that charge continues for 23 minutes.
    Report Abuse
    • Reply
  • darrell kirby
    on Apr 30 2012 15:31 PM
    Verified Answer
    Prodigy20 points
    does TI offer a single cell lipo charger to better suit my needs? more specifically, is there one with 3 leds?
    ( a charge indicator, a done charging indiator and a nother when no battery is present that turns off when a dead battery is plugged in)
    thanx
    Darrell@kirbysite.net
    Darrell Kirby
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
