• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Battery Management » Battery Management - Chargers Forum » BQ24083EVM Vil Vih testing
Share
Battery Management
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
David Frederiksen
Posted by David Frederiksen
on May 01 2012 14:35 PM
Prodigy30 points
Hello everyone,
I am testing the BQ24083EVM and during my testing I came across a problem I can not quite solve.  I am testing for the Vil and Vih of the CE and VBSEL pins and according to the datasheet I am suppose to get a Vih of 1.4V or higher and a Vil of 0 to 0.4V.  I am using a step search using a source meter and record the Vih at 0.92V and Vil at 0.91V.  I am hoping that I can get some insight on a possible alternative method to test this or maybe there was suppose to be a test condition that was not recorded in the datasheet.  Thank you for your time.
http://www.ti.com/litv/pdf/slus848a     (BQ24083 datasheet)
http://www.ti.com/litv/pdf/sluu315      (BQ24083EVM user guide)
BQ24083 Vih Vil
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Tahar Allag
    Posted by Tahar Allag
    on May 01 2012 17:36 PM
    Genius13560 points
    Hi David,
     Yes, the VIL and VIH should work as in the datasheet spec. In the EVM, we use jumper JMP5 and JMP4, with 20KOhms pulled to Vin for both CE AND VBSEL . Use a pull up resistor for both of these pins than vary the pull up voltage. This should be a good test. Of course you to power up the IC for proper operation.
     -Tahar
    Report Abuse
    • Reply
  • David Frederiksen
    on May 02 2012 09:53 AM
    Prodigy30 points
    Thank you for your input.  I just wanted to confirm my setup with you on this.  I have two sourcemeters, one to power the evaluation board and the other to test the Vil Vih.  I am powering the board at 5V and the other source is connected to either JMP4 that is connected to the CE pin and I have placed a 20K resistor in series with the JMP4 and source.  Then I still produce the wrong Vil Vih values.
    Report Abuse
    • Reply
  • Tahar Allag
    on May 02 2012 13:24 PM
    Verified Answer
    Verified by David Frederiksen
    Genius13560 points
    David,
    Yes your testing method is right. What do you call wrong values? The datasheet guaranties low for any values below 0.4V and high for any values above 1.4V. Between 0.4V and 1.4V we do not guaranty it to be low or high.
    -Tahar
    Report Abuse
    • Reply
  • David Frederiksen
    on May 03 2012 00:21 AM
    Prodigy30 points
    Ah, we thought that our Vih value had to be above 1.4V and Vil value below 0.4V.  This was very helpful and we thank you for your time.  One other quick question, is there upper ESD diodes in this charger?  We tested and were able to measure the lower ESD diode in each of the pins, but not the upper.
    Report Abuse
    • Reply
  • Tahar Allag
    on May 03 2012 11:27 AM
    Genius13560 points
    Hi David,
     All pins of the IC meet the specified ESD performance.
     -Tahar
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
