• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Battery Management » Battery Management - Chargers Forum » BQ24070 - Startup with battery only fails
Share
Battery Management
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Robert Tyrakowski
Posted by Robert Tyrakowski
on May 11 2012 08:55 AM
Prodigy60 points
I'm successfully using BQ24070 in a project. Everything works as expected, but there is a single effect I can not explain.
The problem is: Starting with no power from AC adapter and the battery is also not connected. If I then connect the
battery first time , I do not get sufficient power at OUT pin. After the battery is disconnected and immediately connected
second time , everything is ok.
I found that if OUT  voltage is below 0.2 V, I just get 2.0V (+0.5V saw-tooth ripple) after battery connection. If OUT voltage is
more than 0.2 V (approximately), everything works.
Is there an advice what I'm  doing wrong ?
Thank you.
Robert
BQ24070
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Tahar Allag
    Posted by Tahar Allag
    on May 14 2012 08:49 AM
    Verified Answer
    Verified by Robert Tyrakowski
    Genius13580 points
    Robert,
     In your case, there are no power sources and the battery is inserted, the output should track the battery voltage if there is no load (<10 mA of load) on the output. If a load is present, that keeps the output more than 200 mV below the battery, a short-circuit condition is declared.
     If that is the case, the load has to be removed to recover. A capacitor can be placed on the DPPM pin to delay implementing the short-circuit mode and get unrestricted (not limited) current.
     -Tahar
    Report Abuse
    • Reply
  • Robert Tyrakowski
    on May 15 2012 00:50 AM
    Prodigy60 points
    Dear Tahar,
    Thank you. It fixes my problem.
    I did not expect it , because normally there is always a load at the output. Anyway , it works.
    If I would switch to the BQ24079, I assume , such an issues would not appear with that device. Would it be an alternative device to the BQ24070 (in USB mode) with the advantage to disconnect the battery by SYSOFF?
    Thank you very much for your help.
    Robert
    Report Abuse
    • Reply
  • Tahar Allag
    on May 15 2012 08:56 AM
    Genius13580 points
    Robert,
    Try to add a cap on the DPPM mode to delay the short circuit mode. This may help as well.
    Regarding the bq24079, the short circuit protection without source IN still exists . If the OUT voltage falls below the BAT voltage by 250mV for longer than tDGL(SC2), OUT is turned off. Then short circuit recovery timer then starts counting. After tREC(SC2), OUT turns on and attempts to restart. This ON/OFF cycle will continue until the overload condition is removed.
     -Tahar
    Report Abuse
    • Reply
  • Robert Tyrakowski
    on May 16 2012 03:15 AM
    Verified Answer
    Prodigy60 points
    Tahar,
    Thanks for the information about BQ24079. I'll keep using BQ24070 (also more easy to get).
    Adding a cap fixes my issue perfectly.
    Thanks again.
    Robert
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
