I am using BQ24161 as a BATTERY CHARGER with power management. I am connecting DRV with TS as shown in attached file. I could not enable the charging process. It shows battery temperature fault from status register.
When I disable the TS Function from register 0x07, it starts charging but after 40-50 seconds it disable the charging process and shows battery temperature fault. Why this happens? May be because of wrong values of resisters? Please help to figure out this problem.
Thanks.
