I designed PCB with BQ40Z60 based on BQ40Z60EVM board, only I changed FET to more stronger.
I can connect with PCB via SMBus, discharg. is work, current and voltage monitor is work, but I have a problem with charging.
When I set CHARGING EN then BQ. is heats up do 70 deg. I don't know why, he consumption 80mA via VCC pin but why?
I check all soldering pads and it's look ok.
Maybe you have some idea why it happens?
