• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Power Management » Battery Management » Battery Management - Chargers Forum » BQ24450 wrong float voltage
Share
Battery Management
  • Forums
  • Announcements
  • Files
  • E2E Wiki
Options
  • Subscribe via RSS
This question is answered
Stefano Bettega
Posted by Stefano Bettega
on May 13 2010 09:38 AM
Prodigy245 points
Hi, we have a similar design:
Vth = 10.5V
Vfloat = 13.8V
Vboost = 14.7V
Vin = 16.9V
Imaxchg = 250mA
and we obtained the following results in ohm (all resistors are 1%, with except for Risns that is 5%):
Ra = 214.6k   (choosed: 216k = 200k + 16k)
Rb = 17.24k (choosed: 17k = 16k + 1k)
Rc = 46.4k (choosed: 47k)
Rd = 586.8k (choosed: 582k = 5602k + 22k)
Rp = 1143 (choosed: 1100)
Risns = 1
Rt = 406 (choosed: 500)
As transistor we choosed a BCP53.
We choosed to use the configuration with a diode (we choosed an 1N4007) and with Rc tied to /PGOOD.
We cannot achieve the 13.8V float voltage, but we only have 13.2V on battery terminals.
Another question is about Vrch. If we follow the formula for the example given on datasheet, the voltage threshold for the example's battery to be recharged should be
Vrchg = 0.9 * Vref * (Ra + Rb) / Rb = 0.9 * 2.3V * (75k + 16.9k)/16.9k = 11.26V, that is quite over the full battery voltage.
Is this formula correct?
Thanks in advance
Stefano Bettega
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Chris Glaser
    Posted by Chris Glaser
    on May 13 2010 10:29 AM
    Verified Answer
    Verified by Chris Glaser
    Guru59305 points
    I split this thread as the other thread had gotten quite lengthy.
    The recharge voltage is 90% of the float voltage.  The battery voltage this corresponds to is set by Ra and Rb.  This is the voltage at which the charger initiates a new charge cycle.
    Based on the resistors you choose, the float voltage should be 13.7V.  What temperature is this test run at?  Is the IC hot?  The reference voltage is designed to change with temperature.
    Which transistor topology are you using?  Is the battery voltage sensed after the diode?
    Can you post a schematic?
    Try increasing your input voltage a little bit.  You may be in dropout.
    BQ24450
    Report Abuse
    • Reply
  • Stefano Bettega
    on May 20 2010 09:39 AM
    Prodigy245 points
    Hi Chris,
    see attached the currently used circuit topology (please don't take into account the pin labeled 14V1).
    We are using a BCP53 PNP transistor and a L4007 diode. Sensing is done on battery, after the diode.
    I found I missed something in calculating the correct recharge threshold: the formula on the datasheet is given for the simple charger topology in figure 3, where you have only Ra, Rb and Rc. For a complex topology, involving Rd like the one in figure 5, you have to take care about a third resistance, so your formula may be rewritten taking into account that Ra = Ra+Rb and Rb = Rc. This should fix the calculation, giving Vrch=12.3V.
    Well, we tried to discharge the battery until it reached 11.9V, but when charging only 150mA will flow from battery charger to battery.
    IC is comfortably warm, only transistor will heat up, but still into a reasonable temperature. Our input voltage is now fixed to 13Vca, thus leading to 18.3Vdc at the charger input pin.
    Report Abuse
    • Reply
  • Chris Glaser
    on May 20 2010 09:54 AM
    Guru59305 points
    Thank you for posting the schematic.  What issues are you still trying to debug?
    Where did you measure the 150 mA?  As you know, the charging current is set simply by R75.  Measure the voltage from pin 2 to pin 3--measure it at the pins of the IC.  This voltage should be at 250 mV.  If it is and the current is still off, the resistance used for the measurement is wrong--either the sense resistor value is off (check the power capability of its package) or the IC is not using a Kelvin sense connection to the resistor and is seeing additional resistance in traces.
    Report Abuse
    • Reply
  • Stefano Bettega
    on May 20 2010 10:57 AM
    Prodigy245 points
    Three main concerns about this schematic are not so clear for us.
    1. charge current
      1. as you suggested the maximum charge current is fixed by R75, but as the value is 1R 5%, we cannot justify the measured current of 150mA, unless we assume the charger is not working in boost mode, feeding the battery with a constant current
      2. R75 is really close to IC, so I'm quite sure there is no additional trace resistance measured (this could not be real for battery voltage sensing)
      3. we are measuring current with an analog tester in mA mode (it's an Italian ICE model 680 R), 20000 Ohm/V in DC,class two
    2. boost voltage
      1. we have never seen a voltage higher than 13.2V measured on the battery, so we think the charger is really not working in boost mode (even when we discharged the battery to 11.9V)
    3. when disconnecting battery which voltage should we expect? I expect to find Vfloat. Is this correct?
    An interesting thing could be a way to sense if a battery is really connected to the charger (i.e. the protection fuse is not blown). Doing a logical AND between STAT1 and STAT2 pins, if both are OFF (logical level high) should carry an high logical level only when no battery is connected. Is this correct?
    Thanks in advance
    Stefano Bettega
    Report Abuse
    • Reply
  • Chris Glaser
    on May 20 2010 12:42 PM
    Guru59305 points
    If there is no battery, the IC will regulate the output at Vfloat.  This assumes that the load current is less than the maximum charge current, as set by R75.
    Both STAT pins will be off if the battery is fully charged and the IC is regulating in float mode.  See figure 4.
    To set the fast charge current, the IC looks at the voltage between pins 4 and 1, not 2 and 3 as I originally stated.  Measure the voltage between pins 1 and 4 and we can see if the IC is regulating the set charge current.  If this is substantially less than 250 mV, then it could be tapering the charge current while the battery voltage is being regulated at Vboost.  Measure the voltage from pin 13 to pin 6 at this point and see if it is at 2.3V.  If it is, then the IC is tapering the charge current.  I also recommend looking at the above pins/signals with a scope to make sure they are truly at DC, which they should be.
    Another to try might be blowing some air across the IC or using freeze spray to see if the boost voltage changes.  Neglecting any component variation/tolerance, to get a 13.2V boost voltage instead of 13.7V (what your resistors set it to) only requires about 24 C of temperature rise.  If it is a small board, then this is a very possible amount of rise.
    I recommend testing this charger with a lab power supply and resistors instead of a battery.  This is a more predictable test setup that can be varied to all the different charge states without waiting for a battery pack to charge/discharge.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
