My customer confirmed PH pin voltage with default external component and no system load and battery, then the negative voltage over abs max rating though the duration was just about 300msec. Do you think this negative voltage will cause of damage?
Attached waveform was taken with default components, so please check this by yourself.
bq24616EVM Negative voltage on PH pin.pdf
Sonoki / Japan Disty
