Hi Sir,
I am using the D+/D- detectionn of BQ25895 for the test of divider adapter (Apple and Samsung based adapter). However, I found a very small possibility that the BQ25895 D+/D- detectionn failed to identify the divider type adapter. I doubt it might be caused by the noise on the USB connector. I would like to confirm with you guys on the BQ25895 debounce time (deglitch time). It will be helpful for the charger circuit debugging. Thanks in advance.
