Hi
Im using the BQ24090 battery charger for charging a li-po 3.7V 110mAh. also i use a fuel gas that is need a pre-configure.one of the parameters that i need to set is my charger taper current.
what is the BQ24090 taper current? were i can find this parameter ?
thanks
