There is some problem with BQ25895M.
1. Symptom : BQ25895M doesn't work with Battery when Vbus diconnected. It occurs occasionally
2. Test Condition
1) Booting with Battery (3.6 ~ 4.2V)
2) Connect Charging Adapter(Travel Adapter) to Vbus => Charging status indicated.
3) Disconnect Travel Adapter from Vbus => System Power OFF occurred occasionally. (about 3 times/100 times)
==> At that time PMID / SW / SYS pin out is around 0.2~0.4V and REGN and TS is 0V.
Could you let me know why this kind symptom is occurred?
I attached schematic.
Please see attached, and let me get your answer ASAP.
Nicky
