Hi Team,
My customer is using our BQ24650 in new project. But they met some problem and want to check with you, thanks a lot.
Customer use the typical application circuit in page 1 of BQ24650's datasheet. They set the MPPT to 17.8V, and connected to solar panel. When the light is not strong, the solar panel's open circuit voltage is about 20V. When connected to BQ24650 circuit, as these is no enough current, the panel's output voltage dropped, but in our datasheet, it seems charger current will be decreased and keep the charger voltage about 17.8V, however, in customer's situation, it charge Intervally, that means not continuously charge by changing the current. Can you give some expertise advice for this problem? Is these something wrong with customer's application or is these something wrong of the datasheet?
The solar panel voltage waveform as below:
Thanks a lot for your support!
Sulyn Zhang
