We usually use a charger for battery management, but the impendance is different for each battery.when two batteries are charged in parallel,the current flowing into each battery is different.
Maybe one battery voltage is higher than another one,the current may flow into the lower voltage battery.Can this operate correctly?
In another case,two batteries are charged in series.Although the current is the same for every battery,due to different impendance,each battery voltage is different.How to ensure that each battery is charged fully?
Thanks!
