Hi ,
We designed 8800mAH battery charger using BQ24616RGER IC. but we are facing issue with battery charging. When I probe using oscilloscope at the inductor switching terminal I see it switches and turn off immidiatly. I see only 200mAmps current flows it switches to 1A at starts and switches between 400mA to 200mA.
Attached the circuit. R60, R61,R62 replaced with 10K resistor to limit the current.
charger input voltage is 15Volts/5Amps,
Rgds
Chandra
