We are using BQ25895 for charging application
The battery charger section, we are observing following issues.
- STAT pin is indicating IC is in charging mode, but we are not observing any charge current flowing into the battery.
- When mains is removed, the output voltage on PMIC pin drops to 3.6 V even though boost operation is enabled via OTG pin. Cannot observe switching waveform on SW pin.
Plz support with this issue.
Rgds,
Yash
